watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
Do I have the arrow on the #1 spark plug wire? This is a distributor for a 2.0l stock FI engine.
![]() --Rob |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
You can clearly see the index mark on Thompsons post. Watson, its hard to see the right mark on that poor beatup diz, but its there (I think).
Type 47,That mark is NOT for adjusting valves. Its only for indexing the #1 plug. If the diz fires at 27degrees before top dead center, where do you think you valves are? I can tell you they are not both closed. If you point the rotor at that mark (notice that mark is directly under the #1 plug wire tower), and you are timed properly, Your #1 cylinder is at 27 degrees before top dead center. |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
If the diz fires at 27degrees before top dead center, where do you think you valves are? I can tell you they are not both closed. Actually, at 27ยบ BTDC Compression - yeah - they are both closed, and have been for a while... But that's a technicality. The rest of your points are spot-on... |
Lo-Fi Version | Time is now: 21st June 2024 - 02:30 PM |
