ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
So last weekend, at the Autocross my 2.4L six started making a distressing noise. It came home on a trailer, and I spend some days trying to troubleshoot it.
Intermittent pinging type noise, not consistent. Compression check was good across the board at 125, good oil pressure, and nothing else wrong I could find. Had a friend listen to it, and he thinks it is coming from the #5 cylinder. Today I drained the oil and pulled the LH lower valve cover. Nothing is out of place and everything still looks good. So I pulled the the screen off the bottom of the engine... Oh (IMG:style_emoticons/default/stromberg.gif) !!! Large bits of bearing material! (IMG:style_emoticons/default/headbang.gif) This really pisses me off because I just did the top end on this motor. So my six is down and Betty's 4 is running very poorly, because it has a worn out 2.0 in it. I pulled her 1.8 down to rebuild it. I have all the parts, just need to clean, clean, clean...... |
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
Sorry Clay. As some say in Arkansas... dang it all. Good thing you know how to fix that machine. Let the beer flow.
Lo-Fi Version | Time is now: 25th June 2024 - 06:12 PM |
