ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
So last weekend, at the Autocross my 2.4L six started making a distressing noise. It came home on a trailer, and I spend some days trying to troubleshoot it.
Intermittent pinging type noise, not consistent. Compression check was good across the board at 125, good oil pressure, and nothing else wrong I could find. Had a friend listen to it, and he thinks it is coming from the #5 cylinder. Today I drained the oil and pulled the LH lower valve cover. Nothing is out of place and everything still looks good. So I pulled the the screen off the bottom of the engine... Oh (IMG:style_emoticons/default/stromberg.gif) !!! Large bits of bearing material! (IMG:style_emoticons/default/headbang.gif) This really pisses me off because I just did the top end on this motor. So my six is down and Betty's 4 is running very poorly, because it has a worn out 2.0 in it. I pulled her 1.8 down to rebuild it. I have all the parts, just need to clean, clean, clean...... |
ClayPerrine |
What I really need is a 964 core long block......
Anyone know where I can find one? |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
What I really need is a 964 core long block...... Anyone know where I can find one? You really want a 964? Just loosen some oil fittings on the engine you have and tell people it's a 964. Leaking POSs, as far as I'm concerned. We service a few of them, and they've ALL been apart for leaks ....................... The Cap'n |
Lo-Fi Version | Time is now: 25th June 2024 - 05:36 PM |
