Toad Twice in 8 Days, TG for AAA |
76-914 |
Apr 7 2010, 09:54 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,514 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
So Sunday a week ago the thing died in Von's parking lot. No problem. (IMG:style_emoticons/default/headbang.gif) I Called AAA and 21 min's later they show up. Fuel pump took a crap and luckily I have a pressure gage in the old clock hole so it was an easy diagnosis. But it started right up that nite after cooling a bit. Installed a new pump Friday. Today, I pull pull into CVS after a 150mi round trip, pick up a prescription, go to start and nutin. The pump ran and everything lit up inside but I never heard the solonoid click either. So, AAA to the rescue again. Man those guys are fast. So guess what? After sitting for 2 hours it cranks right up. (IMG:style_emoticons/default/screwy.gif) I'm thinking it's old (like me) and just needs to stop and rest once in awhile. Or a Gremlin. (IMG:style_emoticons/default/happy11.gif) I'm hoping it's the solonoid. I have a spare starter/solonoid assm that I'll use in place of it, (IMG:style_emoticons/default/confused24.gif) Thoughts?????
TROJANMAN |
Apr 8 2010, 09:53 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
This happened to one of my cars recently.
Mine would still push start, but no click when you turned the key. And it was completely random when it happened. Troubleshot EVERYTHING and it ended up being a bad ignition switch. Always check the easy stuff first. Oh, and wear gloves so that you don't get warts from the Toad |
76-914 |
Apr 8 2010, 10:10 AM
This happened to one of my cars recently. Mine would still push start, but no click when you turned the key. And it was completely random when it happened. Troubleshot EVERYTHING and it ended up being a bad ignition switch. Always check the easy stuff first. Oh, and wear gloves so that you don't get warts from the Toad I've read about switch problems so many times here that I am a bit suspect of the switch. I tried the switch at least 15 times before settling on the wrecker wescue. Is it possible for the ign switch to respond after setting for a few hours ie cool down a bit. Do the contacts wear to a point that resistance causes heat build up in the switch thus preventing contact? BTW what is the test procedure for the ign switch? |
Lo-Fi Version | Time is now: 18th June 2024 - 07:04 AM |
