Brake Master Cylinder Flex, you'll be surprised |
McMark |
Apr 7 2010, 10:33 AM
https://www.youtube.com/watch?v=CUdPmitJ9XQ Took this video to post in my "Hold the phone!" build thread, but for those who might miss it, this is a repost. |
pcar916 |
Apr 9 2010, 06:10 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Obviously for those with big-brakes only, the Mercedes 23mm cylinder butts up the the stock crossmember.
It was slightly long, but all I had to do was grind off a bit from the end of the MC and add a thin, stiff plastic sheath around the cross-member and it was done. This is better, no movement at all. I've never looked at it's flex directly but it's GOT to be moving a little. Time for an inspection. I'll climb under the car sooner than expected and check for wear. |
0396 |
Apr 9 2010, 08:17 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Obviously for those with big-brakes only, the Mercedes 23mm cylinder butts up the the stock crossmember. It was slightly long, but all I had to do was grind off a bit from the end of the MC and add a thin, stiff plastic sheath around the cross-member and it was done. This is better, no movement at all. I've never looked at it's flex directly but it's GOT to be moving a little. Time for an inspection. I'll climb under the car sooner than expected and check for wear. Can you please post a picture so we can 'see' exactly what your referring too? Thank you! |
pcar916 |
Apr 9 2010, 12:19 PM
I'll climb under the car sooner than expected and check for wear. Can you please post a picture so we can 'see' exactly what your referring too? Thank you! Glad to. It'll be a couple of days but I'll post it when I get it!! (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 26th September 2024 - 05:22 PM |
