> Rear Vented Rotors, Big Tires, Clearance Issues, Options for installing as much tire as you can with vented rotors...
Eric_Shea
post Mar 28 2010, 05:37 PM
PMB Performance
This should be an important thread for those looking to get as much tire under the rear using vented rotors.
If you want to install vented rotors on a 914 you have a couple of options:
1. Pony up about $600.00 to have a pair of 914-6/GT rotors imported from Porsche DE. They're still available.
2. Put a 5mm rotor spacer under the hat of a 911 rotor. Our vented rear caliper kits come with a set of these spacers. If you want to cram as much meat under your rear fender (and a lot of us do) this will eat into 5mm of your tire space.
3. Put 5mm spacers underneath the caliper mounting ears. This will now have your calipers rubbing right up against the handbrake adjustment tube on most cars (some there is no issue).
4. Try a 944 rear rotor but, you would have to mill 2.5mm off the caliper and the mounting ears (spread the 5mm distance between the two) because the offset is too far out.
I finally dug into this today as I tried a set of 944 rotors for fit. No go. I wasn't about to mill my factory 914-6/GT calipers either. Next...
I could buy the 914-6/GT rotors. While $600.00 is a tad much for a pair of rotors, it's not that much in the grand scheme of things.
While I was under the car trying the 944 rotors I decided to see if my arms would work with the calipers spaced back. It fit but, it was rubbing on the arm where the handbrake adjustment tube is welded through the arm. I was only a few short steps away from solving this problem and then I could use a more affordable 911 rear rotor. I ended up getting out a bur grinder and finishing the edges of the handbrake arm tube. There was easily 5mm there to grind off and the bur grinder made short work of it.
(IMG:http://www.914world.com/bbs2/uploads_offsite/hphotos-snc3.fbcdn.net-1110-1269819442.1.jpg)
Here's the area that needed to be ground down:
(IMG:http://www.914world.com/bbs2/uploads_offsite/hphotos-snc3.fbcdn.net-1110-1269819442.2.jpg)
Here's the bur at work. If you do this on freshly powdercoated arms, make sure you put layers and layers of duct tape down first. I didn't have any and the bur "will" jump and nick the arms. Better yet, hopefully you'll see this thread "before" you powdercoat your arms and do this then:
(IMG:http://www.914world.com/bbs2/uploads_offsite/photos-a.ak.fbcdn.net-1110-1269819442.3.jpg)
Basically 1/2 way there on this side:
(IMG:http://www.914world.com/bbs2/uploads_offsite/photos-f.ak.fbcdn.net-1110-1269819442.4.jpg)
With the grinding work done, I needed to protect the metal:
(IMG:http://www.914world.com/bbs2/uploads_offsite/photos-f.ak.fbcdn.net-1110-1269819443.5.jpg)
I used a Testors paint marker and laid it on thick:
(IMG:http://www.914world.com/bbs2/uploads_offsite/hphotos-snc3.fbcdn.net-1110-1269819443.6.jpg)
Done:
(IMG:http://www.914world.com/bbs2/uploads_offsite/hphotos-snc3.fbcdn.net-1110-1269819443.7.jpg)
The calipers mounted up perfectly. I actually had two different spacer combinations on the car. about 4.8mm on the drivers side and a full 5mm on the passengers side:
(IMG:http://www.914world.com/bbs2/uploads_offsite/hphotos-snc3.fbcdn.net-1110-1269819443.8.jpg)
Here you see the spacers under the mounting ear. Basically "washers" in various thicknesses. The Ferrari factory did the same thing to make up for manufacturing differences on their mounts... not a problem:
(IMG:http://www.914world.com/bbs2/uploads_offsite/photos-d.ak.fbcdn.net-1110-1269819443.9.jpg)
Wheels are mounted back on:
(IMG:http://www.914world.com/bbs2/uploads_offsite/hphotos-snc3.fbcdn.net-1110-1269819444.10.jpg)
And I'm keeping my fingers crossed that this much meat will actually fit under the car now! LOL
(IMG:http://www.914world.com/bbs2/uploads_offsite/photos-c.ak.fbcdn.net-1110-1269819444.11.jpg)
Eric_Shea
post Apr 12 2010, 01:03 PM
PMB Performance
Thanks,
That's Saturn Yellow/Chrome Yellow. Here's some links to the build:
http://www.facebook.com/album.php?aid=2057...mp;l=b421a958ac
http://www.facebook.com/album.php?aid=2113...mp;l=d147b32ef5
http://www.facebook.com/album.php?aid=2556...mp;l=3c26455147
http://www.facebook.com/album.php?aid=3924...mp;l=7c2510bef5
Eric_Shea   Rear Vented Rotors, Big Tires, Clearance Issues   Mar 28 2010, 05:37 PM
sixnotfour   Dang that tire and wheel combo looks Good. :chow:   Mar 28 2010, 05:50 PM
DNHunt   Cool Eric So, 911 rear rotors and grind the trail...   Mar 28 2010, 05:56 PM
Eric_Shea   Cool Eric So, 911 rear rotors and grind the trai...   Jun 11 2013, 12:09 PM
Eric_Shea   No. That should be good with 914-6 calipers.   Mar 28 2010, 05:57 PM
Dr. Roger   is the inner rotor diameter clearance of 914/6 cal...   Mar 28 2010, 06:39 PM
Eric_Shea   Yes. Six rotors are a little larger in diameter an...   Mar 28 2010, 08:47 PM
396   This should be an important thread for those look...   Mar 28 2010, 09:23 PM
RJMII   I thought you were in Brasil? That's some n...   Mar 28 2010, 09:52 PM
Eric_Shea   Those are Goodyear Bluestreaks on 8x15. They...   Mar 28 2010, 10:02 PM
396   Thanks for the info.. I once had 245's on a se...   Mar 28 2010, 11:20 PM
Eric_Shea   Those would have been 8x16. Different offset. Th...   Mar 29 2010, 08:39 AM
Kargeek   I did this many moons ago ago..911 rear rotors, 91...   Mar 29 2010, 04:13 PM
J P Stein   If your tire is that close to the swing arm, be da...   Mar 29 2010, 04:40 PM
396   If your tire is that close to the swing arm, be d...   Mar 29 2010, 11:21 PM
sean_v8_914   that photo makes me want to say "gas, gas, ga...   Mar 30 2010, 09:36 AM
Porcharu   I think a flap wheel on an angle grinder would be ...   Mar 30 2010, 04:31 PM
J P Stein   Yes, well, that pic shows "a bridge to far...   Apr 1 2010, 11:53 AM
Loser_Cruiser   Of topic, but what is the color or color code for ...   Apr 12 2010, 12:43 PM
Eric_Shea   Thanks, That's Saturn Yellow/Chrome Yellow. ...   Apr 12 2010, 01:03 PM
Eric_Shea   :bump: for Jim Hoyland   Mar 12 2011, 02:42 PM
- Lo-Fi Version Time is now: 20th April 2025 - 12:22 AM
