JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,074 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
For my most recent Megasquirt install i went a different route and had some mini-MS boards produced. It did not make a lot of sense to just have one PCB printed so needless to say i have more then a few empty boards laying around. Now i am trying to decide if it is worth my time and money to build these boards out and sell them as a plug n play solution for d-jet cars.
For those who don't know, mini-ms is electronically compatible with megasquirt 2.2 however the components are arranged tighter on the board and it integrates the relay board all on a form factor smaller then the original MS. My first couple of installs i used a standard megasquirt 2.2 with relay board and DB-37 cable but the mini-ms seemed like the better way to go so that is what i am playing with now. The setup i a running right now looks almost stock, the mini-ms is enclosed completely in a gutted d-jet brain and plugs directly into the d-jet harness. the only difference from stock is a MAP line running to the brain and the 2 injector ground wires being run back as well. You have to look close to tell its not stock, however i have a feeling i could make it even more stealth by hiding the MAP sensor in an old MPS in order to get rid of the vac line to the ECU. I just have not cared enough to cut up an MPS yet. The great part about this system is it makes troubleshooting way easier and eliminates the need for stock trigger points, MPS. ECU, decell valve, and cold start injector, though they can all be left in place if desired in order to appear stock. It also allows for cool things if you desire like closed loop operation with a wideband O2 sensor, spark control, rev limiters, traction control, and a bunch of other stuff depending on how far you want to take it. It can be tuned around just about anything, so its great if you want to change cams or go bigger on your motor and still look stock. So is there any interest out there for this sort of thing or should i just dump the empty boards on ebay or something? |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
PNP really doesn't exist...
Too many variables in operating conditions, fuel grade and fuel specifics and even differences in stock engines. Tuning and fiddling will always be necessary. |
904svo |
904SVO ![]() ![]() ![]() Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 ![]() |
PNP really doesn't exist... Too many variables in operating conditions, fuel grade and fuel specifics and even differences in stock engines. Tuning and fiddling will always be necessary. I will agree with Jake, I am trying to install MS1 on a 1.7 ltr test engine. Tuning and fiddling with it all the time I just can't get MS to hold a tune for me the VE tables and timing tables have to be changed ever time I run the engine. |
JamesM |
PNP really doesn't exist... Too many variables in operating conditions, fuel grade and fuel specifics and even differences in stock engines. Tuning and fiddling will always be necessary. I will agree with Jake, I am trying to install MS1 on a 1.7 ltr test engine. Tuning and fiddling with it all the time I just can't get MS to hold a tune for me the VE tables and timing tables have to be changed ever time I run the engine. That is strange, I have not had that issue with my cars. could you give me more details on your setup? |
Lo-Fi Version | Time is now: 18th April 2025 - 07:02 PM |
