obscurity |
Member ![]() ![]() Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States ![]() |
I have been drilling spot welds as I work on my car and it occured to me that there may be a better way (or maybe I am being to picky). I am curious what everyone else uses.
I have been using a spot weld cutter. It looks like a short drill bit with a pilot point and little cutters along the edge. It will cut through the top layer or steel but not the back layer (usually). They will cut about 10 welds before being hoplessly dull. When I was buying them at $5/bit it was fine but that company went out of business and the ones I find now are $25/bit. Are these the right tools to use or should I be just using a drill bit allthe way through the weld. Any help or tool suggestions would be appreciated. (IMG:style_emoticons/default/smile.gif) Thanks, John W. |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
harbor freight spot weld drill I use has done 3 suspension consoles, 3-4 battery trays and 2 trunks. they try to walk if your technique is off, this breaks the pilot tip. I drill a small 1/8 pilot dimple. start teh "circle" cut slow then lay into it once the "cut track" is about 1/16-1/8 deep
Lo-Fi Version | Time is now: 26th June 2024 - 07:19 AM |
