Drilling Spot Welds, What do you use? |
obscurity |
Apr 15 2010, 08:09 AM
Member Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
I have been drilling spot welds as I work on my car and it occured to me that there may be a better way (or maybe I am being to picky). I am curious what everyone else uses.
I have been using a spot weld cutter. It looks like a short drill bit with a pilot point and little cutters along the edge. It will cut through the top layer or steel but not the back layer (usually). They will cut about 10 welds before being hoplessly dull. When I was buying them at $5/bit it was fine but that company went out of business and the ones I find now are $25/bit. Are these the right tools to use or should I be just using a drill bit allthe way through the weld. Any help or tool suggestions would be appreciated. (IMG:style_emoticons/default/smile.gif) Thanks, John W. |
1968Cayman |
Apr 15 2010, 04:23 PM
Redacted by Irving Washington Group: Members Posts: 116 Joined: 5-February 10 From: Holly Springs, GA Member No.: 11,332 Region Association: South East States |
In the past I used a spot weld removal tool; if you're doing several cars or several panels that can become expensive.
Now I used DeWalt Pilot-Tip bits. They don't run like other bits and you can usually buy a complete set for $17- and use at least four of the bits to drill welds (all of the pilot-tipped ones if you don't mind the larger holes). |
Lo-Fi Version | Time is now: 27th September 2024 - 01:10 PM |
