Help me determine my compression ratio |
Cevan |
Apr 14 2010, 11:45 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
So I've started my engine build and have the engine mocked up to measure the deck height. My preliminary measurements are around .030. I've got to do some juggling around of components to get them more equal to each other. Here's what I've got:
head volume: 58.2 CCs bore: 96mm stroke 71mm Based on the cam I'm using here's what I get for different deck heights: .040 static C/R 8.84:1 dynamic C/R 7.76:1 .050 8.63:1 7.57:1 .055 8.53:1 7.48:1 .060 8.43:1 7.4:1 The engine is going in a 914 (obviously) that will be used for spirited street driving. I have 93 octane gas available here. The car will be driven between sealevel and 1000'. I'm using webers with SSI H/Es and a Bursch muffler. |
ME733 |
Apr 16 2010, 08:37 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
.............034ths inch is way too CLOSE as a deck height...P/H...piston to head clearance....you can assemble it that way, but if you EVER overrev it you will flat spot the rod bearings.....look at you own compression ratio calculations.....AT .040 ths the compression ratio is 8.84...at...050 ths deck height =8.63.....Do you really think that a 0.21 CR change on a street engine will make ANY significant horsepower change ???. IT will not......you can improve the engines H.P. output, revability,and longevity, by taking (a lot) of time to precisely balance all the rotating components., ensureing port matching of heads, manafolds,carburators,.stacks,.and getting a really good set of dual valve springs with proper seat pressure...and I highly recommend .050ths inch piston to head clearance for a street engine...unless you have a lot of experience in assembling engines...and take the time to clay check EACH piston to head clearance measurement....using .040 ths inch as a minimum....then use .050ths as you will have a safety margin. I am Intrested in how you have established a dynaminic C.R.on an unassembled non- running engine.......................
Cevan |
Apr 16 2010, 10:07 AM
.............034ths inch is way too CLOSE as a deck height...P/H...piston to head clearance....you can assemble it that way, but if you EVER overrev it you will flat spot the rod bearings.....look at you own compression ratio calculations.....AT .040 ths the compression ratio is 8.84...at...050 ths deck height =8.63.....Do you really think that a 0.21 CR change on a street engine will make ANY significant horsepower change ???. IT will not......you can improve the engines H.P. output, revability,and longevity, by taking (a lot) of time to precisely balance all the rotating components., ensureing port matching of heads, manafolds,carburators,.stacks,.and getting a really good set of dual valve springs with proper seat pressure...and I highly recommend .050ths inch piston to head clearance for a street engine...unless you have a lot of experience in assembling engines...and take the time to clay check EACH piston to head clearance measurement....using .040 ths inch as a minimum....then use .050ths as you will have a safety margin. I am Intrested in how you have established a dynaminic C.R.on an unassembled non- running engine....................... Whoa there cowboy. I'm not making any assumptions here. And I didn't say or infer that a .21 change in CR would or wouldn't make any significant difference in horsepower. If you read my title, I'm asking for help in setting my compression ratio and deck height. So I appreciate your input. As for the dynamic C/R, I used the compression ratio calculator from the website that makes Keith Black pistons (the ones I'm using) as Dave D mentioned. |
Lo-Fi Version | Time is now: 26th September 2024 - 05:20 PM |
