don9146 |
Member ![]() ![]() Group: Members Posts: 199 Joined: 3-January 04 From: Nashville, TN Member No.: 1,500 Region Association: None ![]() |
I am just curious if anyone else had a problem with the ball fitting into the cup when you tried to attach the accelerator pedal? I have tried putting a little silicone lube on the cup, but it still hasn't worked. Any other ideas to try?
Thanks, Don |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,712 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(don9146 @ Mar 5 2004, 04:50 AM) Any other ideas to try? heat it up (the plastic part that is) using a blow-dryer. that'll make the plastic a bit more flexible. lube up the ball good and then pound it in. if you don't heat it up, you have a good chance of cracking the plastic ... Andy |
Lo-Fi Version | Time is now: 1st July 2024 - 03:32 AM |
