Traditional Limited Slip vs. Torque Bias, Please eduficate me! |
SirAndy |
Apr 22 2010, 03:40 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Purpose of the car, in order:
Spirited street driving, occasional AX, occasional track days. Here's what i think i know (IMG:style_emoticons/default/biggrin.gif) LSD - Always locks wheels together under acceleration and deceleration. - Introduces understeer in slow corners. - Generally considered the better choice for the big track. TB - Only locks wheels under acceleration. - Acts like a open diff if a driving wheel is off the ground. So, the question is, what should i get for my 915??? The car will never be a dedicated track car, it's mostly driven on the street. The TB seems to be easier to drive on the street. However, the slow corner understeer of a LSD could probably be tuned down with suspension settings. The TB loses it's magick if one wheel is off the ground. In an AX setting, the suspension would need to be pretty stiff to keep both wheels on the ground at all times, would a LSD be the better choice here? Anyone compared the two back to back in a 914? (IMG:style_emoticons/default/idea.gif) Andy |
r_towle |
Apr 22 2010, 06:00 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Track, Limited Slip, no question.
AX, Torque Bias for the simple fact that you can drive the car as you need to in an Autox...with a Limited slip you MUST do burn outs to get around tight corners... Given your motor, you can use either one. Torque Bias has little to no maintenance where a Limited Slip has a clutch pack that needs to be changed and maintained...which in the case of a 915 tranny is not a simple nor a cheap thing to do...you may end up having to reset the pinion depth but I dont know how the unit is designed (like can you swap out the clutch pack from just one side???) I would go with whatever Guards recommends...he has alot more knowledge than most people about these things...and he sells both units. Rich |
Lo-Fi Version | Time is now: 26th June 2024 - 07:07 AM |
