bfrymire |
Salsaholic ![]() ![]() ![]() Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California ![]() |
Always seems to be something fix or upgrade. Neverending. But, we all like that right?
So, I wanted to move the battery into the trunk, and at the same time, use a AGM battery (26lbs vs 36lbs). Well, here it is mounted using the billet mount. The PO cut a hole in the trunk for starter access, so, I decided to put this to use. (Yes, I do plan to clean up the hole.) ![]() Someone else did something simliar, and I had asked about the wires that normaly attach to the positive post. So, I used a battery bulkhead connector and attached the wires using that. You can see it in this photo next to the petronix. Here's the post unmounted. ![]() Inside engine bay. ![]() More in next post.... (Still have to fix that big hole in the firewall, put new bars and shocks in the front, and fix an engine miss. <sigh> Don't think I am going to make the AX this weekend...) -- brett |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Correct me if I'm wrong, but don't you want the weight between the axles and as low as possible?
The Cap'n |
bfrymire |
Correct me if I'm wrong, but don't you want the weight between the axles and as low as possible? The Cap'n Yes. I wanted the battery out of the engine compartment. I was aware of the placement, and just picked a good place to mount. Ideally, it should be moved forward more. (And no, I don't want to put it in the front trunk.) The next step after this, is to corner balance the car. I still plan to make adjustments, such as moving the battery around if need be. Thanks for the comment. (Good point!) -- brett |
Lo-Fi Version | Time is now: 20th June 2024 - 05:29 AM |
