bfrymire |
Salsaholic ![]() ![]() ![]() Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California ![]() |
Always seems to be something fix or upgrade. Neverending. But, we all like that right?
So, I wanted to move the battery into the trunk, and at the same time, use a AGM battery (26lbs vs 36lbs). Well, here it is mounted using the billet mount. The PO cut a hole in the trunk for starter access, so, I decided to put this to use. (Yes, I do plan to clean up the hole.) ![]() Someone else did something simliar, and I had asked about the wires that normaly attach to the positive post. So, I used a battery bulkhead connector and attached the wires using that. You can see it in this photo next to the petronix. Here's the post unmounted. ![]() Inside engine bay. ![]() More in next post.... (Still have to fix that big hole in the firewall, put new bars and shocks in the front, and fix an engine miss. <sigh> Don't think I am going to make the AX this weekend...) -- brett |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
It's been 5 years since I stuck this here. @11lbs you can put it where ever you want. I could have put it in the front trunk but the cabling would weigh as much as the battery. (IMG:style_emoticons/default/dry.gif) This makes for very convenient runs for the various wires....like the main feed for the MSD & starter/charging. Bout ready for a new one, me thinks.
Attached thumbnail(s) ![]() |
bfrymire |
It's been 5 years since I stuck this here. @11lbs you can put it where ever you want. I could have put it in the front trunk but the cabling would weigh as much as the battery. (IMG:style_emoticons/default/dry.gif) This makes for very convenient runs for the various wires....like the main feed for the MSD & starter/charging. Bout ready for a new one, me thinks. Part of what I am working toward is a ligther car, and simplification. Short wires = both. I do like your placement better than mine, and that is an easy fix. As far as heat from the muffler, probably still less than being in the engine bay. I can place a probe and measure it. -- brett |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
It's been 5 years since I stuck this here. @11lbs you can put it where ever you want. I could have put it in the front trunk but the cabling would weigh as much as the battery. (IMG:style_emoticons/default/dry.gif) This makes for very convenient runs for the various wires....like the main feed for the MSD & starter/charging. Bout ready for a new one, me thinks. Part of what I am working toward is a ligther car, and simplification. Short wires = both. I do like your placement better than mine, and that is an easy fix. As far as heat from the muffler, probably still less than being in the engine bay. I can place a probe and measure it. -- brett With the lid on, it gets REALLY hot, much hotter than the original location. The Cap'n |
Lo-Fi Version | Time is now: 20th June 2024 - 05:21 AM |
