don9146 |
Member ![]() ![]() Group: Members Posts: 199 Joined: 3-January 04 From: Nashville, TN Member No.: 1,500 Region Association: None ![]() |
I am just curious if anyone else had a problem with the ball fitting into the cup when you tried to attach the accelerator pedal? I have tried putting a little silicone lube on the cup, but it still hasn't worked. Any other ideas to try?
Thanks, Don |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(Ferg @ Mar 6 2004, 09:52 AM) A couple of times when I let off it would not come back all the way and the car would idle at about 1500., and it was noticable slower to decell between shifts. make sure your pedal cluster is in good (clean & greased) shape. add a second throttle-return spring on the engine side of things. that should take care of the sticking pedal ... Andy |
Lo-Fi Version | Time is now: 26th June 2024 - 07:00 AM |
