don9146 |
Member ![]() ![]() Group: Members Posts: 199 Joined: 3-January 04 From: Nashville, TN Member No.: 1,500 Region Association: None ![]() |
I am just curious if anyone else had a problem with the ball fitting into the cup when you tried to attach the accelerator pedal? I have tried putting a little silicone lube on the cup, but it still hasn't worked. Any other ideas to try?
Thanks, Don |
echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
So is pent some more time affixing the stock cup to the alum pedal.
I cut the stock pedal down more and trimmed a recess in the back to fit in the aluminum pedals roundish- square area, I will be using two allen screws and lock nuts to keep them attached. I moved the cup up about an inch to keep it the same as the stock position Attached image(s) ![]() |
Lo-Fi Version | Time is now: 1st July 2024 - 04:17 AM |
