don9146 |
Member ![]() ![]() Group: Members Posts: 199 Joined: 3-January 04 From: Nashville, TN Member No.: 1,500 Region Association: None ![]() |
I am just curious if anyone else had a problem with the ball fitting into the cup when you tried to attach the accelerator pedal? I have tried putting a little silicone lube on the cup, but it still hasn't worked. Any other ideas to try?
Thanks, Don |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
QUOTE source that AJ-USA and the other vendors use Look identical to the AJ unit.. could be a knock off.. a customers car in my firends shop has th AJ pedals... same plastic block in the back....Ill sneak a peak at the pedal next time the car is in the shop.. |
Lo-Fi Version | Time is now: 1st July 2024 - 04:05 AM |
