JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,580 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Eyeballing alignment of the rotor to the tick mark on the dizzy body seems so imprecise...for adjusting valves. Is there a method of locating TDC for each cyl PRECISELY?
1. I thought about making some kind of rotor replacement device with a pointer that could extend down close to the tick mark, but thats only good for cyl 1. All cylinders needed. 2. I thought about making a special trigger point plug adapter with three long wires, and attaching it to me DVM on the buzzer setting. When the trigger points would make contact, then that would indicate...? I am not sure that the trigger points make contact at TDC, I think it is at some different point in the cycle. Any time proven methods? |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,596 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Just do this the easy way.....
Take off BOTH valve covers. Hook up a remote starter switch. Look at the valves for #2 (front left cylinder). Bump the engine until the exhaust valve opens. Because the engine only has 4 cam lobes, the exhaust valve on #4 will be on the base circle, ready to be adjusted. Adjust that one, and bump the engine until the intake valve on #2 opens, then adjust the intake valve on #4. Bump it again and the intake on #1 will open, so adjust the intake valve on #3. Bump it again until the exhaust valve on #1 opens, and adjust the exhaust valve on #3. Now repeat front to back on the other side. It is simple, and it works every time. |
Lo-Fi Version | Time is now: 30th June 2024 - 07:48 PM |
