How to determine EXACTLY where TDC is?, Valve adjustment advice needed |
JeffBowlsby |
May 2 2010, 10:34 AM
914 Wiring Harnesses Group: Members Posts: 8,580 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Eyeballing alignment of the rotor to the tick mark on the dizzy body seems so imprecise...for adjusting valves. Is there a method of locating TDC for each cyl PRECISELY?
1. I thought about making some kind of rotor replacement device with a pointer that could extend down close to the tick mark, but thats only good for cyl 1. All cylinders needed. 2. I thought about making a special trigger point plug adapter with three long wires, and attaching it to me DVM on the buzzer setting. When the trigger points would make contact, then that would indicate...? I am not sure that the trigger points make contact at TDC, I think it is at some different point in the cycle. Any time proven methods? |
r_towle |
May 2 2010, 05:19 PM
Custom Member Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Jeff, I can get you onto two.
Via the timing hole in the fan housing, you see the notch at #1 TDC Crawl underneath and mark the lower window at the flywheel to mark number 3... Then, if your so inclined...remove the engine and divide the two marks to get two more... Rich |
Dave_Darling |
May 2 2010, 10:28 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Then, if your so inclined...remove the engine and divide the two marks to get two more... Nope, the crank goes through TWO rotations when the cam (and distributor) go through one. So the two marks on the flywheel or fan are all you need, one of them will always be TDC for both #1 and #3, the other will be TDC for #2 and #4. BTW, it appears that the fans can be off slightly from example to example. The ignition Tech Article on Pelican's site shows two fans that are slightly off from each other. I would trust the flywheel mark before the fan markings. But it isn't generally necessary to be right exactly on TDC when you're using the TDC method for valve adjusting. And it isn't necessary at all if you use the opposite-rocking method... --DD |
Lo-Fi Version | Time is now: 30th June 2024 - 07:55 PM |
