Solving V8 Conversion overheating, Exhausting out the HOOD is THE answer |
stewteral |
Apr 24 2010, 11:00 AM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Hey V8 conversion 914ers,
I’ve been running my car for some 7 years now and chose to exhaust the radiator out the bottom of the car. It seemed to work fine, but in the 100 degree summer heat of Willow Springs, I was seeing water hitting 250 degrees with fans blazing. We all know that from the 60’s, race cars have vented out to TOP of the hood and it worked well for a friend’s Corvair 327 Chevy we ran at Riverside (142 MPH on the short course back straight). However, I originally didn’t want the car to look too “radical.” When I got the car running it had 11” fender flairs, side scoops, roof scoop and a wing……Ya’ cops won’t notice my car! With some time before my next event, I redid the whole radiator layout where I sealed the bottom of the trunk, HACKED a hole in the hood and fabricated radiator shrouding and an exhaust air dam. I upgraded my fans too. This morning in 60 degree temps, I took the car for a drive AROUND town at low speeds to see if I could keep it from overheating in traffic, as it used to. What I found surprised me: I drove the whole run with NO fans and water temp at 140 degrees. When I was caught by a stop light, the temp went up to 160, but once moving again, it moved back down. I jumped on the freeway and both oil and water dove down to 120 again. EUREKA, I have found my solution! Conclusion: -Of course 120 is lower than desired, in spite of the 180 degree T-stat, but I’m aiming at the right temp ON-Track in Summer. If I want to so some street driving, I can always tape off some of my intake opening. -In the previous configuration, I would have had to run the radiator + oil cooler fans and worry about over heating, now with NO fans, the temps are on the low side. -Before, the oil temp would exceed the water temp by some 30 degrees, now the oil matched the water temps, at least in street driving. -The internal hood bracing defines the hole shape as a trapezoid, so I cut all the width I could get right to left. The back edge is defined by the rear wall of the trunk and from there I measured 12” forward, held my breath, and cut. -If your V8 car is on the edge of overheating and big fans aren’t enough, give this a try. Mine is a pure “racer” design, but our friend byndbad914 came up with an attractive louvered approach that keeps his 500 HP small-block cool. In another design, AndyS created a very attractive molded “air dam” for his LS1 conversion. Being pleased to see all the work was worth it, I wanted to pass it along. Best, Terry Attached image(s) |
ChrisFoley |
May 4 2010, 10:37 AM
I am Tangerine Racing Group: Members Posts: 7,958 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Thanks for those details Terry.
We have a LS-6 powered 914 at the shop right now and one of the problems is melted plastic items in the engine compartment. This seems to have become a serious problem since the engine lid was sealed off, which was done because the owner thought it would help keep heat out of the cockpit when he drives with the roof off. I told him that opening the engine lid is necessary and a good way to provide interior cooling must be arranged. I'm interested in your roof scoop but with the radiator outlet in the front deck lid I would think the scoop might draw in hot air from the radiator. |
stewteral |
May 4 2010, 11:03 AM
Thanks for those details Terry. We have a LS-6 powered 914 at the shop right now and one of the problems is melted plastic items in the engine compartment. This seems to have become a serious problem since the engine lid was sealed off, which was done because the owner thought it would help keep heat out of the cockpit when he drives with the roof off. I told him that opening the engine lid is necessary and a good way to provide interior cooling must be arranged. I'm interested in your roof scoop but with the radiator outlet in the front deck lid I would think the scoop might draw in hot air from the radiator. Hey Racer Chris, The quickest, easiest way to prove the benefits of "opening up the engine cover" would be simply loosening the 2 ten-millimeter bolts and REMOVE the cover. The difference should be dramatic. I'd be interested to know the drop in the water temps. I've heard a lot of concern about only getting hot air through my roof scoop, but have found that the radiator exhaust temps are not much higher than ambient. Even though I'm dumping a lot of heat, the transfer occurs via such a large volume of air, that by the time it gets to the scoop, it still can cool me down. If one is still not convinced, using 2 small scoops over the driver & passenger would move them outboard of the center radiator exhaust. Good luck with your customer, Terry |
Lo-Fi Version | Time is now: 26th September 2024 - 05:23 PM |
