JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,074 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
For my most recent Megasquirt install i went a different route and had some mini-MS boards produced. It did not make a lot of sense to just have one PCB printed so needless to say i have more then a few empty boards laying around. Now i am trying to decide if it is worth my time and money to build these boards out and sell them as a plug n play solution for d-jet cars.
For those who don't know, mini-ms is electronically compatible with megasquirt 2.2 however the components are arranged tighter on the board and it integrates the relay board all on a form factor smaller then the original MS. My first couple of installs i used a standard megasquirt 2.2 with relay board and DB-37 cable but the mini-ms seemed like the better way to go so that is what i am playing with now. The setup i a running right now looks almost stock, the mini-ms is enclosed completely in a gutted d-jet brain and plugs directly into the d-jet harness. the only difference from stock is a MAP line running to the brain and the 2 injector ground wires being run back as well. You have to look close to tell its not stock, however i have a feeling i could make it even more stealth by hiding the MAP sensor in an old MPS in order to get rid of the vac line to the ECU. I just have not cared enough to cut up an MPS yet. The great part about this system is it makes troubleshooting way easier and eliminates the need for stock trigger points, MPS. ECU, decell valve, and cold start injector, though they can all be left in place if desired in order to appear stock. It also allows for cool things if you desire like closed loop operation with a wideband O2 sensor, spark control, rev limiters, traction control, and a bunch of other stuff depending on how far you want to take it. It can be tuned around just about anything, so its great if you want to change cams or go bigger on your motor and still look stock. So is there any interest out there for this sort of thing or should i just dump the empty boards on ebay or something? |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
I have a schedule to have an engine running within 3 months and would love a modern digital FI system. Would one of yours be ready for me? I'm willing to be a Guinea Pig for your R & D ... at my expense.
JamesM |
Technically i could have one ready in a couple days. Idealy though I would really like to give it a serious stress test myself before i ship one out to anyone else. I am also still making changes to the system, the more i mess with it the more i find ways to improve it and until i have finalized all the changes i would like to keep it in house. I just built another board today with some modifications i wanted to test out however i feel that if all the modifications work as expected it will be pretty close to final. 3 months might be doable for guinea pig testing but i will have to see. I was considering some pretty specific criteria for anyone who wants to be involved in initial testing in order to simplify things for me, however that is still up in the air as well.
Give me the details on your car and motor so i can at least have it in my head to think about. For initial testing i was planning more on cars that are close to stock in order to eliminate variables however i am willing to consider anything. I have a schedule to have an engine running within 3 months and would love a modern digital FI system. Would one of yours be ready for me? I'm willing to be a Guinea Pig for your R & D ... at my expense. |
Lo-Fi Version | Time is now: 18th April 2025 - 06:55 PM |
