JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,580 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Eyeballing alignment of the rotor to the tick mark on the dizzy body seems so imprecise...for adjusting valves. Is there a method of locating TDC for each cyl PRECISELY?
1. I thought about making some kind of rotor replacement device with a pointer that could extend down close to the tick mark, but thats only good for cyl 1. All cylinders needed. 2. I thought about making a special trigger point plug adapter with three long wires, and attaching it to me DVM on the buzzer setting. When the trigger points would make contact, then that would indicate...? I am not sure that the trigger points make contact at TDC, I think it is at some different point in the cycle. Any time proven methods? |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Okay, since Dave upped the ante: (IMG:style_emoticons/default/poke.gif)
You should confirm the zero TDC mark by pulling a spark plug and looking into the cylinder with a flash light. You can see the piston as it moves up the cylinder and can visually identify TDC. Then check your fan to make sure the TDC mark corresponds. THEN you can move on. (IMG:style_emoticons/default/tongue.gif) |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,643 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Okay, since Dave upped the ante: (IMG:style_emoticons/default/poke.gif) You should confirm the zero TDC mark by pulling a spark plug and looking into the cylinder with a flash light. You can see the piston as it moves up the cylinder and can visually identify TDC. Then check your fan to make sure the TDC mark corresponds. THEN you can move on. (IMG:style_emoticons/default/tongue.gif) Or, better still - buy or borrow a bore-scope. |
Lo-Fi Version | Time is now: 30th June 2024 - 07:35 PM |
