Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
After putting new bushings in the trans bracket for the shifter rod, I still had a lot of slop. Taking it apart and measuring found the following. New Bushings are 0.600 inside dia and 0.815 outside dia. My bracket hole for the bushing is 0.830 and my rod is 0.588. Made another bushing for the rod that is slightly larger. Will get back later to let all know how it turns out.
Also made a couple of bushings for the yoke at the fire wall. Press fit and hone to fit pin. This tightened up that area very well. I used a white delrin material to make the bushings out of as this material is supposed to be good for this type of application. ![]() ![]() ![]() Later, Tom |
Nürburg Nomad |
914Rubber.com! ![]() ![]() Group: Members Posts: 296 Joined: 30-March 10 From: Buckeye State Member No.: 11,536 Region Association: Upper MidWest ![]() |
Hmm well I see they have part number PEL-SKS914-03N which has a firewall bushing specifically for early 914s with sideshift so perhaps I'll go with that $48.40 set if there aren't any better suggestions?
http://www.pelicanparts.com/catalog/shopca...t_pg1.htm#item0 |
Lo-Fi Version | Time is now: 20th June 2024 - 11:30 PM |
