JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,580 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Eyeballing alignment of the rotor to the tick mark on the dizzy body seems so imprecise...for adjusting valves. Is there a method of locating TDC for each cyl PRECISELY?
1. I thought about making some kind of rotor replacement device with a pointer that could extend down close to the tick mark, but thats only good for cyl 1. All cylinders needed. 2. I thought about making a special trigger point plug adapter with three long wires, and attaching it to me DVM on the buzzer setting. When the trigger points would make contact, then that would indicate...? I am not sure that the trigger points make contact at TDC, I think it is at some different point in the cycle. Any time proven methods? |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
What I am not seeing is how I adjust the distributor to get my rotor pointed where it is supposed to be? I have top dead center & have my timing mark in the hole. How do I get my rotor to the right position (IMG:style_emoticons/default/confused24.gif)
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
What I am not seeing is how I adjust the distributor to get my rotor pointed where it is supposed to be? I have top dead center & have my timing mark in the hole. How do I get my rotor to the right position (IMG:style_emoticons/default/confused24.gif) You don't change the rotor position, you change the orientation of the distributor body. Loosening this with a 10mm wrench will allow the body to rotate. If your distributor drive gear was put in correctly, your distributor is pretty close to right. Probably close enough to start. I can talk your ear off about all the 'philosophy' of distributor orientation at WCR. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 30th June 2024 - 07:19 PM |
