How to determine EXACTLY where TDC is?, Valve adjustment advice needed |
JeffBowlsby |
May 2 2010, 10:34 AM
914 Wiring Harnesses Group: Members Posts: 8,580 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Eyeballing alignment of the rotor to the tick mark on the dizzy body seems so imprecise...for adjusting valves. Is there a method of locating TDC for each cyl PRECISELY?
1. I thought about making some kind of rotor replacement device with a pointer that could extend down close to the tick mark, but thats only good for cyl 1. All cylinders needed. 2. I thought about making a special trigger point plug adapter with three long wires, and attaching it to me DVM on the buzzer setting. When the trigger points would make contact, then that would indicate...? I am not sure that the trigger points make contact at TDC, I think it is at some different point in the cycle. Any time proven methods? |
JRust |
May 10 2010, 08:51 AM
914 Guru Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
What I am not seeing is how I adjust the distributor to get my rotor pointed where it is supposed to be? I have top dead center & have my timing mark in the hole. How do I get my rotor to the right position (IMG:style_emoticons/default/confused24.gif)
McMark |
May 10 2010, 10:07 AM
What I am not seeing is how I adjust the distributor to get my rotor pointed where it is supposed to be? I have top dead center & have my timing mark in the hole. How do I get my rotor to the right position (IMG:style_emoticons/default/confused24.gif) You don't change the rotor position, you change the orientation of the distributor body. Loosening this with a 10mm wrench will allow the body to rotate. If your distributor drive gear was put in correctly, your distributor is pretty close to right. Probably close enough to start. I can talk your ear off about all the 'philosophy' of distributor orientation at WCR. Attached image(s) |
SLITS |
May 10 2010, 10:39 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
What I am not seeing is how I adjust the distributor to get my rotor pointed where it is supposed to be? I have top dead center & have my timing mark in the hole. How do I get my rotor to the right position (IMG:style_emoticons/default/confused24.gif) You don't change the rotor position, you change the orientation of the distributor body. Loosening this with a 10mm wrench will allow the body to rotate. If your distributor drive gear was put in correctly, your distributor is pretty close to right. Probably close enough to start. I can talk your ear off about all the 'philosophy' of distributor orientation at WCR. Just to make it more confusing ...... The distributor does not give a crap where it is as long as you have enough "swing" to get the advance you want. What the engine does care is that the #1 high tension wire, pole on cap and the rotor are in alignment plus the firing order is correct. Moving high tension leads can account for a misaligned distributor drive gear. |
ClayPerrine |
May 10 2010, 10:49 AM
Life's been good to me so far..... Group: Admin Posts: 15,596 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Just to make it more confusing ...... The distributor does not give a crap where it is as long as you have enough "swing" to get the advance you want. What the engine does care is that the #1 high tension wire, pole on cap and the rotor are in alignment plus the firing order is correct. Moving high tension leads can account for a misaligned distributor drive gear. Actually that is not quite true. Some of the beetle and 411 distributors have a 2 degree retard on the point opening for the #3 cylinder. This was done because #3 runs the hottest, and that helps to prevent detonation. So if you get the rotor in wrong, and rearrange the plug wires, it could retard the timing on the wrong cylinder. |
Lo-Fi Version | Time is now: 30th June 2024 - 07:19 PM |
