Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
After putting new bushings in the trans bracket for the shifter rod, I still had a lot of slop. Taking it apart and measuring found the following. New Bushings are 0.600 inside dia and 0.815 outside dia. My bracket hole for the bushing is 0.830 and my rod is 0.588. Made another bushing for the rod that is slightly larger. Will get back later to let all know how it turns out.
Also made a couple of bushings for the yoke at the fire wall. Press fit and hone to fit pin. This tightened up that area very well. I used a white delrin material to make the bushings out of as this material is supposed to be good for this type of application. ![]() ![]() ![]() Later, Tom |
Tom |
Well, it has been several years now and shifting is still very good.
I used the delrin because I was having trouble finding oilite. An engineer at the shipyard told me most oilite applications were shifting to delrin. NOMAD, you would need to take measuremeents for some one to custom make a set for you. Do you have any friends with a lathe? Otherwise new bushings from a supplier will make things better, just not best. Tom |
Lo-Fi Version | Time is now: 20th June 2024 - 11:30 PM |
