SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Ok, tore down the Grey Ghost's engine to determine what happened on the way to Wickenburg ... images below:
I am missing something: (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1273510232.1.jpg) Oooooo, that hurts: (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1273510232.2.jpg) Bits and pieces: (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1273510232.3.jpg) Tested all factors on the CIS and flow on the injectors is within 5% of each other. Analysis: Cylinders 1 & 2 on a flat six are the poorest cooled of all. Apparently, #1 got hot and detonated (poor gas, bad timing) and broken ring lands / rings were the result. Oh well, now in search of a good used Mahle P&C. I will be adding a Cylinder Head Temperature Gauge to #1 cylinder to monitor temps from now on. Thank you Ferry, where ever you are in the universe ............... |
ahdoman |
It's phonetic...Ah-D-O-Man (Audioman) ![]() ![]() ![]() Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California ![]() |
Ron - When you put that back together make sure you do the cooling tin mod mentioned on the Pelican website. I think it really helps. I did it on the 2.7 I put in the Turd and it stays very even in temp.
Did you find out what made that engine so special? Is the cam grind different? HC CIS pistons? |
SLITS |
Ron - When you put that back together make sure you do the cooling tin mod mentioned on the Pelican website. I think it really helps. I did it on the 2.7 I put in the Turd and it stays very even in temp. Did you find out what made that engine so special? Is the cam grind different? HC CIS pistons? Didn't really investigate. It may just be one of the "better" stock engines the factory produced. Haven't pulled a camshaft to see if it a different grind. Need to check the timing on the other cam to see if something was done different. Anyway ... just another Por$che project ... (IMG:style_emoticons/default/sad.gif) I have a "loaner" 2.7L in the car now. Loaned to me to find out if it would run and how well. I'll fix the other and put it back in. |
Lo-Fi Version | Time is now: 26th June 2024 - 06:58 AM |
