Larouex |
Larouex ![]() ![]() Group: Members Posts: 144 Joined: 22-July 08 From: Larouex@gmail.com Member No.: 9,339 Region Association: Pacific Northwest ![]() |
Hello,
I wanted to document my SDS install as I am doing a few custom steps I haven't seen anyone post yet. I ordered the EFI system with the 02 System (which requires welding in the bung and sensor, more on that later). I already have the Crane Xr700 and the Crane Coil, so my ignition is solid and works well and decided to skip the ignition and crankfire for now. My first goal was to fit the SDS ECU into the existing 914 DJet ECU as I had a couple extra boxes. I am pleased with the results, although I have to mount the O2 sensor and tach boost box, so far I am not sure how I want those items to no be conspicuous in the engine bay. I will post more as I get the install further along, but here are the pics of the box install and fitment... Full image set @ Flickr 914 SDS into ECU Photo Set (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.static.flickr.com-9339-1273641496.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.static.flickr.com-9339-1273641496.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.static.flickr.com-9339-1273641496.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.static.flickr.com-9339-1273641496.4.jpg) |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,631 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Another thing you might consider, though it is an extra expense - Jeff Bowlsby (Bowlsby) and Jeff Keyser (MightyOhm) can make you a custom SDS harness that is much nicer than the one provided by SDS. That is the route I am going and SDS is giving me a $275 credit for harness delete. The Bowlsby MightyOhm harness is shielded for EMI, weatherproof and can have a connector that allows you to unplug your engine for engine drops and leave it wired so reinstallation is just - put the engine back in and plug it back into it's fuel injection harness. Really a neat solution. Perhaps one of them will chime in but it is something you should consider...
Larouex |
Another thing you might consider, though it is an extra expense - Jeff Bowlsby (Bowlsby) and Jeff Keyser (MightyOhm) can make you a custom SDS harness that is much nicer than the one provided by SDS. That is the route I am going and SDS is giving me a $275 credit for harness delete. The Bowlsby MightyOhm harness is shielded for EMI, weatherproof and can have a connector that allows you to unplug your engine for engine drops and leave it wired so reinstallation is just - put the engine back in and plug it back into it's fuel injection harness. Really a neat solution. Perhaps one of them will chime in but it is something you should consider... That would be great, the harness is a sore spot for me and I already did the FI portion of the harness. I have pinged Jeff on his site before and did not get a response, what is the best way to get one of these ordered? |
Lo-Fi Version | Time is now: 26th June 2024 - 09:55 AM |
