carburetor vs fuel injected |
bigjim |
Mar 6 2004, 01:30 PM
Newbie Group: Members Posts: 10 Joined: 5-March 04 From: el centro,ca Member No.: 1,752 |
(IMG:style_emoticons/default/headbang.gif) okay i give up, i want to go to carbuertor here is the question which one to do duals or SINGLE PROGRESSIVE 32/36 i like the idea about one carb any thoughts 1976 2.0l d-jet 914
jim |
7391420 |
Mar 8 2004, 02:42 PM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
OK,,
-I have dual webbers, and the car runs great. I havent had to tune it at all, once it was set up it has been fine for around 7 k miles. -I agree that FI is better because it's more precise, its smoother, and the car will run better and more evenly up the RPM's... But, Answer this, -What about vapor lock, vac leaks, electrical failures-from PO wiring f-ups, 30+ year old electrical issues, and safety issue of a very old fuel system running at 34psi? I would say that if your FI is working right, or if you can put the big$$ into fixing it than it's better. But, if not, carbs are less problematic, easier to fix, and still run pretty good....IE-they are a comprimise, but when set up correctly, they dont comprimise much. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:49 AM |
