GTeener |
914 Girl ![]() ![]() ![]() ![]() Group: Members Posts: 2,348 Joined: 25-June 04 From: SillyCon Valley Member No.: 2,249 Region Association: Northern California ![]() |
OK, so my "bonus" 914 is a stock 2.0 engine. I drove it to work once. Parked it on the street and covered it. It rained a couple days past and I was out of town over the weekend. I took out the trash last night and noticed a dark puddle coming from under the car (rear right side) seeping to the curb. I was warned there were leaky seals but told it was drivable.
So my question is, how much of a leak is too much? Do I just put some 20/50 in every time I go for a drive? I assume the 4-cyl 2.0 engine oil also needs to be checked while the engine is running (IMG:style_emoticons/default/idea.gif) Attached thumbnail(s) ![]() |
GTeener |
Tom Amon did me the favor of looking under the car and assessing what is leaking. He says the "taco plate" is fine. Transmission is dry. He says the valve gaskets need replacing & a lot of brake cleaner to clean up the current mess.
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Tom Amon did me the favor of looking under the car and assessing what is leaking. He says the "taco plate" is fine. Transmission is dry. He says the valve gaskets need replacing & a lot of brake cleaner to clean up the current mess. That's a lot of oil. Valve cover gaskets are easy though. With that much, the oil leak should be easy to find... 914s that sit and then run... leak.. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:22 PM |
