narino |
Member ![]() ![]() Group: Members Posts: 231 Joined: 14-August 07 From: Los Angeles, CA Member No.: 8,001 Region Association: None ![]() ![]() |
When I had the engine put back in the car I noticed the engine tin didn't align with the engine bay anymore. There now was 3" gap between the firewall and the engine tin. I asked the mechanic if there was some adjustment we could do to line up the engine better. He said it was basically a "bolt-up" job and didn't know how to align it further. Today I was looking through George's 700 tips and saw tip #348. Which bascially says if you can't shift into 1st 3rd or fifth, then you've installed the power plant too far back. Sure enough I have had problems with these gears. So how do I go about adjusting the powerplant more forward? I have no idea where the adjustement "play" to move the engine forward or back would be. Any help would be appreciated. (IMG:style_emoticons/default/beer.gif) |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
The front mounts are upside down. Also, the bolts should go up from the bottom so the threads wont get chingered up if you drag the bottom on something.
The Cap'n |
Lo-Fi Version | Time is now: 26th June 2024 - 05:02 AM |
