moparrob |
Senior Member ![]() ![]() ![]() Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None ![]() |
OK, here is a newbie question for you.
When comparing a 1.7 case to a 2.0 case, are the dimensions (width) the same from cylinder base to opposing cylinder base on both engines? The reason I ask is I want to set-up a mock up engine with the 1.7 case I have, with the intention of eventually building a motor based on the 2.0 case. Both motors will be using 1.7 barrels and heads. I want to design an intake and exhaust system on the bench, on the mock up engine (1.7 case), and want to be sure it will bolt up top the 'real' engine (2.0 case) once it is built. (IMG:style_emoticons/default/headbang.gif) Any other concerns or thoughts from anyone who may have some experience with this? Thanks. |
moparrob |
70 914 - you are on the money. I checked out Samba and found LOTS of goodies, even running engines on the cheap.
You are absolutely correct, the magic bullet is the cylinder heads. That is where the bulk of the build money will go. HAM has built some trick heads for Dave that are specially designed for his application (which sounds exactly like what I am looking for). |
70_914 |
Member ![]() ![]() Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest ![]() |
70 914 - you are on the money. I checked out Samba and found LOTS of goodies, even running engines on the cheap. You are absolutely correct, the magic bullet is the cylinder heads. That is where the bulk of the build money will go. HAM has built some trick heads for Dave that are specially designed for his application (which sounds exactly like what I am looking for). Glad you understand to look at your engine as a system, and not just bolt a bunch of random parts together and expect magical results. Good luck! |
Lo-Fi Version | Time is now: 22nd June 2024 - 04:44 AM |
