arkitect |
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None ![]() |
New to this, first post.
Trying to get some opinions on an engine rebuild. I've got a 70 914 with the engine in pieces....should I try to get the parts - pistons, rings, bearings ect. or try to find a good used motor. Assuming it's a 1.7. I know, this is a pretty loaded question. |
craig downs |
Senior Member ![]() ![]() ![]() Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California ![]() |
The way you get the proper end pay is you need a flywheel and 3 shims. You bolt on the flywheel and measure the end play. Then you find the 3 of the right size shims to get your proper end play which is between 4-6 thousand.
Lo-Fi Version | Time is now: 1st July 2024 - 02:27 AM |
