fuel pump problem.. won't prime for some reason, Dr 914/George could you verify markings on China pumps please |
tod914 |
May 26 2010, 06:07 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Put in a nos bosch 3 port pump in my car after changing all the fuel lines. There is gas in both the feed and return line from the firewall to the pump.. no kinked lines there. I checked and checked my fuel line configuration. All seems good..
fat line from fire wall to step hose to filter to S / top of the pump. D line to feed into engine bay. R has the 2 return lines and the bottom of the pump. Now the pump has the correct bosch numbers on it, but does not have the S D R on it. I would think it's the same as my old pump even though it's not marked like that. fuel routing in the engine bay is fine. been over that several times. the pump turns on fine when I turn the key 1/2 way. I tried that like 30 times to try to get pressure to build up. nadda.. even tried pulling feed line in the engine bay to see if that helped. Even ran it directly from the battery for like 10 seconds like the instructions said. Any suggestions on how to get this pump to prime/push fuel? |
tod914 |
May 26 2010, 07:12 PM
Steve, absolutely nothing comes out of "D". Is there a way to unstick that valve your refering to? The missing labels I thought were odd too. But, oddly, it has the Bosch number and made in Germany on the bottom of the case stamped in. Also no yellow paint on the screws. Who knows, maybe it's hybrid Chinese one. I'll try swapping the "S" & "D" tomorrow and see what happens.
Lo-Fi Version | Time is now: 26th June 2024 - 12:00 AM |
