fuel pump problem.. won't prime for some reason, Dr 914/George could you verify markings on China pumps please |
tod914 |
May 26 2010, 06:07 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Put in a nos bosch 3 port pump in my car after changing all the fuel lines. There is gas in both the feed and return line from the firewall to the pump.. no kinked lines there. I checked and checked my fuel line configuration. All seems good..
fat line from fire wall to step hose to filter to S / top of the pump. D line to feed into engine bay. R has the 2 return lines and the bottom of the pump. Now the pump has the correct bosch numbers on it, but does not have the S D R on it. I would think it's the same as my old pump even though it's not marked like that. fuel routing in the engine bay is fine. been over that several times. the pump turns on fine when I turn the key 1/2 way. I tried that like 30 times to try to get pressure to build up. nadda.. even tried pulling feed line in the engine bay to see if that helped. Even ran it directly from the battery for like 10 seconds like the instructions said. Any suggestions on how to get this pump to prime/push fuel? |
Tom_T |
May 27 2010, 01:58 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Anyone use the AA "repro" 3 port fuel pumps, or are these one in the same Chinese problem fuel pumps that George is selling at AA? (IMG:style_emoticons/default/confused24.gif)
dr914@autoatlanta.com |
May 27 2010, 07:28 PM
914 Guru Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Anyone use the AA "repro" 3 port fuel pumps, or are these one in the same Chinese problem fuel pumps that George is selling at AA? (IMG:style_emoticons/default/confused24.gif) We are selling ONLY genuine bosch rebuilt pumps. The chinese ones are not working properly yet. |
Tom_T |
May 28 2010, 02:00 AM
Anyone use the AA "repro" 3 port fuel pumps, or are these one in the same Chinese problem fuel pumps that George is selling at AA? (IMG:style_emoticons/default/confused24.gif) We are selling ONLY genuine bosch rebuilt pumps. The chinese ones are not working properly yet. You may have to go to Bosch or a small mfgr in Euro-land or here in the US/Can to get a good quality repro of the Bosch 3 port FP George. They just don't look at Specs & QC the way we're used to in the rest of the world. There are a lot of the US subcontractors to the Big 3 & Foreign auto mfgrs. who have idle capacity, so maybe a Delco, Borg Warner, or the like would be able to do some small lot work for these & the other hard to find models? .... just a thought! (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:44 PM |
