underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
I'm running a MSII code 2.88. I can't figure out the barometric correction settings on Megatune. Car ran fine, actually good, yesterday morining, then high pressure system came in, now I seem to be rich. What settings have others had good success with? I'm using one sensor BTW.
RJMII |
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None ![]() |
It should automatically adjust for the outside barometric pressure when you shut off the car.
The way it works is that it takes a reading before starting, figures out the kPa of the atmosphere, and makes it's compensations based off of that. (which is how I got away with running the one MAP sensor for my turbo setup) The battery is dead in my car and can't pull up my exact settings for you. (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 03:20 AM |
