Battery in trunk, More on my 914 / Ax project car |
bfrymire |
Apr 23 2010, 08:48 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Always seems to be something fix or upgrade. Neverending. But, we all like that right?
So, I wanted to move the battery into the trunk, and at the same time, use a AGM battery (26lbs vs 36lbs). Well, here it is mounted using the billet mount. The PO cut a hole in the trunk for starter access, so, I decided to put this to use. (Yes, I do plan to clean up the hole.) Someone else did something simliar, and I had asked about the wires that normaly attach to the positive post. So, I used a battery bulkhead connector and attached the wires using that. You can see it in this photo next to the petronix. Here's the post unmounted. Inside engine bay. More in next post.... (Still have to fix that big hole in the firewall, put new bars and shocks in the front, and fix an engine miss. <sigh> Don't think I am going to make the AX this weekend...) -- brett |
PRS914-6 |
May 29 2010, 07:23 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
I guess I'm just a party-pooper. (IMG:style_emoticons/default/slap.gif) I thought the factory did a pretty damn good job placing the battery. It partially offsets the drivers weight and it's almost centered in the middle of the car. It doesn't suck up any trunk space and wiring is a piece of cake. I can't for the life of me figure why the big urge to move it especially with the light weight, leak resistant batteries available today. (IMG:style_emoticons/default/confused24.gif)
Yes, the hell holes are a direct result from batteries but that issue is almost totally resolved with today's batteries Can anyone honestly say they moved a specific battery to a trunk and got a reduced time in a race or noticeably better performance? |
Lo-Fi Version | Time is now: 27th June 2024 - 02:18 AM |
