> Testing Original Custom's Upgraded Speedo Drive Seals, Initial impressions and installation.
Sleepin
post Mar 18 2010, 09:14 PM
My wife's '73 was leaking a huge amount of oil out of the speedo drive. I contacted McMark to try out his newly designed speedo drive.
As you can see, this drive was leaking quite a bit. Just sitting in the garage it would drain out a major spot just in a couple days.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-179-1269017475.1.jpg)
Here is my core sitting next to the new unit. Notice the extra O-ring:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-179-1269017476.2.jpg)
The swap was straight forward. The only difference I noticed from a regular speedo drive was a little persuasion required to very lightly tap the drive into position. I just used a small rubber mallet to accomplish this. I am confident that I did not pinch the O-rings, and it felt like a good solid seal. Once in place without the set screw in, I could not wiggle or move the drive from side to side at all.
A quick fill of the trans:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-179-1269017477.3.jpg)
A quick wipedown to get rid of any oil:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-179-1269017477.4.jpg)
Also put a strip of cardboard underneath the trans...I want to make sure this isn't going to leak.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-179-1269017478.5.jpg)
I will snap another picture underneath in a couple days. I highly doubt that this will leak at all! Such a good idea IMO...I wonder why no one thought of this before!
jflash914
post May 31 2010, 03:06 PM
Hello Sleepin,
Besides removing the set screw what else is needed to remove the speedo drive?? Do you have to remove the back plate of the trans to get the speedo drive out??
Thanks,
Jack
- Lo-Fi Version Time is now: 19th April 2025 - 02:45 AM
