TorqueJunkie |
Newbie ![]() Group: Members Posts: 48 Joined: 25-May 10 From: Baltimore, MD Member No.: 11,760 Region Association: None ![]() |
I am in the process of rebuilding my 2.4 engine with 2.2S pistons, S cams, and am going to install TWM individual throttle bodies. I am looking around for some fuel and ignition systems for this engine. I have looked at most of the ones out there, but not sure what works best. On some of the other forums, there is a guy running the Megasquirt(latest version) with good results. Another guy is using Electromitive. I have everything except for the control module. What do you guys use on the flat 6 engines? I do not want to spend a ton of money either. I want something reliable. I hated my carbs.
puff adder |
Member ![]() ![]() Group: Members Posts: 77 Joined: 9-December 08 From: northern california Member No.: 9,827 Region Association: None ![]() |
Check out the Electromotive Tec III system. I was considering it, but went with 50mm PMO carbs instead.
Lo-Fi Version | Time is now: 29th June 2024 - 12:51 AM |
