Stand alone injection? Opinions? For /6 w ITB, help picking EFI system |
TorqueJunkie |
Jun 3 2010, 04:49 PM
Newbie Group: Members Posts: 48 Joined: 25-May 10 From: Baltimore, MD Member No.: 11,760 Region Association: None |
I am in the process of rebuilding my 2.4 engine with 2.2S pistons, S cams, and am going to install TWM individual throttle bodies. I am looking around for some fuel and ignition systems for this engine. I have looked at most of the ones out there, but not sure what works best. On some of the other forums, there is a guy running the Megasquirt(latest version) with good results. Another guy is using Electromitive. I have everything except for the control module. What do you guys use on the flat 6 engines? I do not want to spend a ton of money either. I want something reliable. I hated my carbs.
J P Stein |
Jun 6 2010, 01:24 PM
I used Link on my 2.4 fuel injection motor. Works perfect. Then why aren't you out there beatin' on it? (IMG:style_emoticons/default/biggrin.gif) Keep this up and you'll beat all my slow to build records. |
Randal |
Jun 6 2010, 02:36 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I used Link on my 2.4 fuel injection motor. Works perfect. Then why aren't you out there beatin' on it? (IMG:style_emoticons/default/biggrin.gif) Keep this up and you'll beat all my slow to build records. Soon JP, soon. |
Lo-Fi Version | Time is now: 29th June 2024 - 12:30 AM |
