Weber IDF always rich- Please help! |
tornik550 |
Jun 13 2010, 08:08 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have dual weber 40 idf's. I cannot get the mixture correct no matter of the changes that I have made. I foul the plugs with dry black soot in only minutes. The car runs fairly well. Could be fine tuned however right now I am working on gross tuning. Heres the background info-
Setup- -1.7l case now 2.27l by changing jugs to 96mm and crank to 78.5mm -2.0l heads (I also have stock 1.7l heads, I have had the same issue with both heads) -A "fairly aggressive webcam camshaft setup for carbs". I do not know the exact lift and such. The previous owner increased the displacement from 1.7l to 2.0l. He changed the cam when he rebuilt the engine. When I rebuilt the engine, I used the same cam. I had this rich mixture issue before and after my rebuild. Carb info- -Dual weber 40 idf's freshly rebuilt with new needles and seats -main jets 120 -air correction jets 200 -tubes- f11 -idle jets 50 -vents 32mm -floats set at 10mm (rich mixture), 11mm (rich mixture), 12mm (rich mixture) -fuel pressure at 3.5 Other Info about my engine- -MSD 6al ignition -MSD Blaster 2 Coil -Bosch 050 distributor with pertronix -Autolite 63 spark plugs gapped at .030 I have tried a few things however I have not been able to change the problem. I only have a set of larger mains which obviously didn't help the issue. I have checked to make sure the needle is seating properly. I have removed the air correction jets to see what would happen- no major change in the mixture. I have a set of 34mm vents on the way however I doubt that will change much. It seems to me that with the carb setup that I currently have, I shouldn't be fouling the plugs after running the engine for only a minute. Any ideas would be greatly appreciated. (Yes, I did post something similar on 914Club. I am trying to look for as many ideas as I can find). |
tornik550 |
Jun 13 2010, 09:59 PM
Its difficult to explain because I have only driven the car for about 10 minutes in the past year. I have not gotten the engine to WOT yet (I usually work on the car at night. I don't want to wake my daughter).
Here is what I remember from my drive last week. Accelerates quick at about 1/2 throttle. Lower RPMs are ok but then high rpms seem to stumble. Not sure if this is connected but when the engine is hot, the rpms go to about 3k when idling, after about 10 seconds the rpms drop down to the point of almost dying. |
Lo-Fi Version | Time is now: 30th January 2025 - 06:26 PM |
