Weber IDF always rich- Please help! |
tornik550 |
Jun 13 2010, 08:08 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have dual weber 40 idf's. I cannot get the mixture correct no matter of the changes that I have made. I foul the plugs with dry black soot in only minutes. The car runs fairly well. Could be fine tuned however right now I am working on gross tuning. Heres the background info-
Setup- -1.7l case now 2.27l by changing jugs to 96mm and crank to 78.5mm -2.0l heads (I also have stock 1.7l heads, I have had the same issue with both heads) -A "fairly aggressive webcam camshaft setup for carbs". I do not know the exact lift and such. The previous owner increased the displacement from 1.7l to 2.0l. He changed the cam when he rebuilt the engine. When I rebuilt the engine, I used the same cam. I had this rich mixture issue before and after my rebuild. Carb info- -Dual weber 40 idf's freshly rebuilt with new needles and seats -main jets 120 -air correction jets 200 -tubes- f11 -idle jets 50 -vents 32mm -floats set at 10mm (rich mixture), 11mm (rich mixture), 12mm (rich mixture) -fuel pressure at 3.5 Other Info about my engine- -MSD 6al ignition -MSD Blaster 2 Coil -Bosch 050 distributor with pertronix -Autolite 63 spark plugs gapped at .030 I have tried a few things however I have not been able to change the problem. I only have a set of larger mains which obviously didn't help the issue. I have checked to make sure the needle is seating properly. I have removed the air correction jets to see what would happen- no major change in the mixture. I have a set of 34mm vents on the way however I doubt that will change much. It seems to me that with the carb setup that I currently have, I shouldn't be fouling the plugs after running the engine for only a minute. Any ideas would be greatly appreciated. (Yes, I did post something similar on 914Club. I am trying to look for as many ideas as I can find). |
Root_Werks |
Jun 14 2010, 10:05 AM
Village Idiot Group: Members Posts: 8,559 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I went through and cleaned out one of my IDF's this weekend, made a big difference, I still have to do the other one. There was a bunch of "gunk" on the bottom of the bowl. Not from a bad fuel tank or anything, I think just becuase the car sat for so long. Up in this thread, I noticed it was mentioned the fuel enrichment parts were in one side and not the other. Both my carbs have the block off plates, but when I removed the one side, I noticed there were no parts? On later IDF's did they simply keep the casting the same and just not drill out the passages?
I don't have a running rich problem or anything, but have heard very bad stories if you remove the arm cover for the block off plate and don't keep the two parts in the carb as well as make sure they stay down with a little set screw or something. So are my carbs normal or should I be looking for parts? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 30th January 2025 - 06:18 PM |
