Gigamight |
Member ![]() ![]() Group: Members Posts: 220 Joined: 8-June 09 From: Near Akron, Ohio Member No.: 10,454 Region Association: Middle East ![]() |
Actual questions are in bold for those that want to skim the unimportant crap.
So I got a package deal from a guy a while back, and he said he had "almost new bilsteins, front and back." Well, installing the rears is no big deal, but I have minimal tools at my disposal, and no air tools at all, so the fronts may be different. I have a complete rack from that 6k mile car I cut up, that seems to have great ball joints and tie rods... the works, and so I am planning on using that on my project car. Here are the questions: First of all, are the shocks in the front just inserts inside that canister? Or is it the whole deal? The front Bilseins are attached to the front spindle/assembly still, and the guy cut the ball joint to get them off, so I don't think I can use that, but I want to use the shocks if I can. Or, can I get that ball joint out without herculean effort? Can I easily swap out the cartridges in the shocks? The Bilsteins were on a 75, the front suspension I am using is a 72, does that matter? Do I even come off at all like I know what I am talking about? I will take pics of something if that helps. just tell me what you want to see. |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
There are 2 types of Bilstein inserts - one was the factory option green struts & Bilstein inserts, which are apparently a PITA to change inserts compared to the Boge struts because the require almost a complete R&R of the strut assy. just to change the inserts IIRC. Those inserts will only fit into those struts/towers, with the fat part down IIRC, which is probably why the full/part disassembly is required to change them.
Whereas, Bilstein still makes inserts to fit into the Boge (black struts/housings), which are an easier job to just pop in/out at the top. But those only fit into the Boge Struts. So it depends on which you have. If the struts are cut up by a DAPO, then just go with the Boges & get new or lightly used Bilstein or Koni inserts as to you preference, but most advise to match same brand & type (HD, Sport, etc.) F&R at all 4 corners. No comment on the last - (IMG:style_emoticons/default/biggrin.gif) ... we're all learning new stuff & someone just told me about the difference & PITA in the green Bilstein struts a few weeks ago myself! I have early 80's vintage Koni Reds/HDs in mine F&R & always liked them! (IMG:style_emoticons/default/driving.gif) |
Gigamight |
Thank you for the reply.
Ok, so let me ask this, how do I remove the top nut to get to the insert once the struts are off the car? Also, how do I know what I have (early or late, Boge or Bilstein)? Aaaaand, what came stock on the car if it wasn't Bilsteins? Boge? Or did I miss something there? Thanks again |
Lo-Fi Version | Time is now: 26th June 2024 - 09:38 AM |
