ldino21 |
Member ![]() ![]() Group: Members Posts: 62 Joined: 18-February 03 From: Fresno, CA Member No.: 316 ![]() |
I am getting ready to replace my stock shocks with Koni Yellow adjustable shocks all around, do most of you find it necessary to also replace the Front Ball joints at the same time?? Is there anything else I should consider repairing or replacing while I am doing this.
Also, I auto-crossed my 73-1.7 this weekend and on the first run my stock stabilizer bar broke off at the U-Tab bracket on the A-Arm. I am going to replace the Stabilizer bar with a 22mm Weltmeister Anti-Sway Bar in its place. Do you guys find it better to just weld the stock U-Tab back on, or should I just grind them off and put the bolt on tabs supplied by Welteister. Any suggestions please..... Lou |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
excuse my ignorance:
I replace the wheel bearing on GPs(general principles) everytime I pull my rotors off the front... on the Ball joint though: how can you know when these need to be replaced? do it when the shocks need it? |
Lo-Fi Version | Time is now: 26th June 2024 - 09:02 AM |
