tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
I am going to install my 25 row Earls oil cooler over the 4th of july and I am looking for some more ideas, tip and tricks.
I plan on using a wafer adapter to keep my filter in the stock location. I will also install a thermostat and a fan. I will most likely mount it under the rear trunk. I'd like to see some pictures of what others have done. Experinces on the wafer adapter vs relocating the oil filter and what thermostats are being used. I've seen the Pelican Article. thanks -Rob |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Cooler under left side of trunk. I have a very low airdam in the front with not much air going under car, so installed a scoop in the left rocker panel with a 3 inch duct for the cooler. Got rid of the Home Depot cowl and fabbed one out of sheet metal. I also used the sandwich plate adapter. The one I used has a thermostat built in.
Attached thumbnail(s) ![]() ![]() |
Lo-Fi Version | Time is now: 18th June 2024 - 07:13 AM |
