tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
I am going to install my 25 row Earls oil cooler over the 4th of july and I am looking for some more ideas, tip and tricks.
I plan on using a wafer adapter to keep my filter in the stock location. I will also install a thermostat and a fan. I will most likely mount it under the rear trunk. I'd like to see some pictures of what others have done. Experinces on the wafer adapter vs relocating the oil filter and what thermostats are being used. I've seen the Pelican Article. thanks -Rob |
Dominic |
Dominic ![]() ![]() ![]() Group: Members Posts: 993 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California ![]() |
This is a picture of my oil cooler set-up, it's a large Setrab cooler with a pull through fan designed as the primary oil cooler for my car. This is for a 4 cyl car with the CFR header that exits on the opposite side so no hot exhaust below this cooler, I am still working on ducting some cool air to the top of the cooler.
Attached image(s) ![]() |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:35 AM |
