Weber IDF always rich- Please help! |
tornik550 |
Jun 13 2010, 08:08 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have dual weber 40 idf's. I cannot get the mixture correct no matter of the changes that I have made. I foul the plugs with dry black soot in only minutes. The car runs fairly well. Could be fine tuned however right now I am working on gross tuning. Heres the background info-
Setup- -1.7l case now 2.27l by changing jugs to 96mm and crank to 78.5mm -2.0l heads (I also have stock 1.7l heads, I have had the same issue with both heads) -A "fairly aggressive webcam camshaft setup for carbs". I do not know the exact lift and such. The previous owner increased the displacement from 1.7l to 2.0l. He changed the cam when he rebuilt the engine. When I rebuilt the engine, I used the same cam. I had this rich mixture issue before and after my rebuild. Carb info- -Dual weber 40 idf's freshly rebuilt with new needles and seats -main jets 120 -air correction jets 200 -tubes- f11 -idle jets 50 -vents 32mm -floats set at 10mm (rich mixture), 11mm (rich mixture), 12mm (rich mixture) -fuel pressure at 3.5 Other Info about my engine- -MSD 6al ignition -MSD Blaster 2 Coil -Bosch 050 distributor with pertronix -Autolite 63 spark plugs gapped at .030 I have tried a few things however I have not been able to change the problem. I only have a set of larger mains which obviously didn't help the issue. I have checked to make sure the needle is seating properly. I have removed the air correction jets to see what would happen- no major change in the mixture. I have a set of 34mm vents on the way however I doubt that will change much. It seems to me that with the carb setup that I currently have, I shouldn't be fouling the plugs after running the engine for only a minute. Any ideas would be greatly appreciated. (Yes, I did post something similar on 914Club. I am trying to look for as many ideas as I can find). |
tornik550 |
Jun 26 2010, 08:41 PM
Unfortunately, it appears that I didn't actually solve my problem. I think that I was having a few issues that were making the rich mixture impossible to diagnose. I had the stuck starter valves which screwed everything up. Things got better when that was fixed however I am still getting a super rich mixture. I also found that I when I purchased my main jets, they had actually been drilled out. I had 140 mains and purchased 120 mains. I measured them recently and found they were identical. Since then I have purchased 115 mains and have drilling them out trying to get the right mixture. I found that around 130 is good for high rpms.
My problem now is that I am rich at idle. I have 45 idle jets which were the smallest that I could find easily. I did see that you could get slightly smaller however it doesn't seem like I should need such small jets. I tried to do an experiment. I turned all of the idle mixture screws in and put a new park plug in to see what would happen. I started the car and ran it at idle only for 1 minute. I then removed the plug and it was fouled. I tried this with seven different types of plugs and I got the same results with all of them. I have tried float settings of 10-12.5 and had fouling troubles with all settings. Is there anything else that I can try? If needed- here is a video clip that I posted on one of my other posts. I was talking about a different issue on the video so ignore that. I didn't show the black smoke form the exhaust. It is present but not horribly bad. I do not kjnow if the video would help, just thought i would post it since I have it. |
tornik550 |
Jun 26 2010, 08:42 PM
Lo-Fi Version | Time is now: 30th January 2025 - 06:17 PM |
