> Weber IDF always rich- Please help!
tornik550
post Jun 13 2010, 08:08 PM
I have dual weber 40 idf's. I cannot get the mixture correct no matter of the changes that I have made. I foul the plugs with dry black soot in only minutes. The car runs fairly well. Could be fine tuned however right now I am working on gross tuning. Heres the background info-
Setup-
-1.7l case now 2.27l by changing jugs to 96mm and crank to 78.5mm
-2.0l heads (I also have stock 1.7l heads, I have had the same issue with both heads)
-A "fairly aggressive webcam camshaft setup for carbs". I do not know the exact lift and such. The previous owner increased the displacement from 1.7l to 2.0l. He changed the cam when he rebuilt the engine. When I rebuilt the engine, I used the same cam. I had this rich mixture issue before and after my rebuild.
Carb info-
-Dual weber 40 idf's freshly rebuilt with new needles and seats
-main jets 120
-air correction jets 200
-tubes- f11
-idle jets 50
-vents 32mm
-floats set at 10mm (rich mixture), 11mm (rich mixture), 12mm (rich mixture)
-fuel pressure at 3.5
Other Info about my engine-
-MSD 6al ignition
-MSD Blaster 2 Coil
-Bosch 050 distributor with pertronix
-Autolite 63 spark plugs gapped at .030
I have tried a few things however I have not been able to change the problem. I only have a set of larger mains which obviously didn't help the issue. I have checked to make sure the needle is seating properly. I have removed the air correction jets to see what would happen- no major change in the mixture. I have a set of 34mm vents on the way however I doubt that will change much. It seems to me that with the carb setup that I currently have, I shouldn't be fouling the plugs after running the engine for only a minute.
Any ideas would be greatly appreciated.
(Yes, I did post something similar on 914Club. I am trying to look for as many ideas as I can find).
tornik550
post Jun 28 2010, 08:06 PM
I just got in from the garage and I am very pleased however I do not know how to interpret my results.
I put new spark plugs in, attached a new fuel pressure regulator and fuel pressure gauge. I turned all of the idle mixture screws all the way in. I tried to start the engine. It started right up and ran as smooth as I have every heard a 914 run. I was shocked by how smooth it was running. It sounded like a completely different engine. I let it run for a few minutes at idle then turned off the engine. Pulled a spark plug and for the first time ever the plug was not fouled. It looked exactly like it did when the plug was brand new.
The engine is running great at idle but from what I understand, it should not be running at all with the idle mixture screws all the way in. What does this mean? I am confused (as aways (IMG:style_emoticons/default/blink.gif) )
Thanks again!
tornik550   Weber IDF always rich- Please help!   Jun 13 2010, 08:08 PM
jmill   I was helping you over on the Club site. Can you ...   Jun 13 2010, 09:01 PM
J P Stein   NGKs in the same or hotter heat range (BP5 or 6ES...   Jun 13 2010, 09:51 PM
tornik550   Its difficult to explain because I have only drive...   Jun 13 2010, 09:59 PM
9146986   I'd check the float valves to make sure they a...   Jun 14 2010, 05:14 AM
jmill   Here is what I remember from my drive last week. ...   Jun 14 2010, 07:31 AM
tornik550   He checked the float valve assembly and he says ...   Jun 14 2010, 08:34 AM
jmill   Last night, I found something that may be a the p...   Jun 14 2010, 09:01 AM
rhodyguy   perhaps i've missed it. what effect do the idl...   Jun 14 2010, 09:24 AM
Root_Werks   I went through and cleaned out one of my IDF's...   Jun 14 2010, 10:05 AM
Root_Werks   Here's more of what I was talking about:   Jun 14 2010, 10:11 AM
jmill   Both my carbs have the block off plates, but when...   Jun 14 2010, 10:17 AM
Root_Werks   Both my carbs have the block off plates, but whe...   Jun 14 2010, 10:18 AM
tornik550   I have kind of an embarrassing/funny story. Tonig...   Jun 14 2010, 07:44 PM
jmill   Glad it all worked out for you. :cheer:   Jun 14 2010, 08:08 PM
Root_Werks   Cool! Before I was told my versions don't...   Jun 15 2010, 08:54 AM
Silverstreak   Victory!!! I hope I am as victorious w...   Jun 15 2010, 04:03 PM
tornik550   Unfortunately, it appears that I didn't actual...   Jun 26 2010, 08:41 PM
tornik550   sorry forgot to add the link http://www.youtube.c...   Jun 26 2010, 08:42 PM
tornik550   I just noticed something on a weber idf diagram. ...   Jun 26 2010, 08:53 PM
jmill   With the O-ring missing you'd suck more air fr...   Jun 26 2010, 09:41 PM
Root_Werks   :agree: There are a total of 4 O-rings per carb,...   Jun 26 2010, 10:34 PM
FourBlades   I am no expert but I got a suggestion lately that ...   Jun 27 2010, 06:05 PM
rhodyguy   when your car is ilding, is fuel spilling/dribblin...   Jun 27 2010, 07:26 PM
tornik550   when your car is ilding, is fuel spilling/dribbli...   Jun 27 2010, 07:36 PM
tornik550   I had two o-rings so I put them on the idle jet ho...   Jun 27 2010, 07:31 PM
tornik550   Here is a brief summary of what I have tried to fi...   Jun 27 2010, 07:53 PM
rhodyguy   you need an o ring for each idle/air mixture needl...   Jun 27 2010, 07:58 PM
FourBlades   Buy a new set of carbs for $500-600 before ta...   Jun 27 2010, 08:01 PM
tornik550   Buy a new set of carbs for $500-600 before t...   Jun 27 2010, 08:13 PM
tornik550   I may have just found my problem. I was having ri...   Jun 27 2010, 08:12 PM
jmill   With the mixture screws turned all the way in your...   Jun 27 2010, 10:40 PM
tornik550   I want to confirm that my engine will run with the...   Jun 28 2010, 07:21 AM
tornik550   I forgot to mention that my mixtures screws look d...   Jun 28 2010, 07:25 AM
tornik550   I just got in from the garage and I am very please...   Jun 28 2010, 08:06 PM
jmill   Your butterflies are misaligned. (see fig. C ) Wh...   Jun 28 2010, 09:18 PM
tornik550   Your butterflies are misaligned. When your butte...   Jun 28 2010, 09:35 PM
tornik550   I did not see the image at first. I think that I ...   Jun 28 2010, 09:44 PM
jmill   I doubt all the seats would be junk. Stranger thi...   Jun 28 2010, 09:45 PM
jmill   If this is the case, how would this happen to bot...   Jun 28 2010, 09:55 PM
tornik550   Mine do say Made in Italy (is that good or bad). ...   Jun 29 2010, 06:02 AM
jmill   Made in Italy is a good thing. Chances are that i...   Jun 29 2010, 06:17 AM
jmill   One more thought. IIRC the butterfly plates are m...   Jun 29 2010, 09:00 AM
rhodyguy   i just checked a set of 40s that i have. there is ...   Jun 29 2010, 10:31 AM
jmill   Thanks for checking that out. :beer2: Whats rea...   Jun 29 2010, 10:53 AM
rhodyguy   no hole in the plates on these italians but the 76...   Jun 29 2010, 11:01 AM
tornik550   I just got back inside from examining my butterfl...   Jun 29 2010, 07:42 PM
jmill   You really want to keep the butterflies as close t...   Jul 1 2010, 06:47 PM
tornik550   I ordered 40s. I figured that I can bore them out...   Jul 1 2010, 06:49 PM
tornik550   Heres the answer. JMill had told my to check to m...   Jul 1 2010, 07:01 PM
tornik550   The problem   Jul 1 2010, 07:02 PM
tornik550   The Solution   Jul 1 2010, 07:03 PM
tornik550   I am really kicking myself for not seeing this. A...   Jul 1 2010, 07:04 PM
FourBlades   No wonder you were not getting enough air into the...   Jul 1 2010, 08:16 PM
jmill   I bet it'll run great now. :cheer:   Jul 1 2010, 09:34 PM
7275914911   Man this place just continues to amaze me!...   May 22 2012, 05:10 PM
Vacca Rabite   Well... shit. I bet this was the root of the super...   May 22 2012, 07:13 PM
jmill   Found these in a rebuild kit but are the floats g...   May 22 2012, 09:22 PM
rhodyguy   HUGE deal with the o-rings. they rest in the reces...   May 23 2012, 08:36 AM
aharder   Well... shit. I bet this was the root of the supe...   May 23 2012, 08:45 AM
SUNAB914   Same here, I have two plugs running rich, no#1 and...   May 23 2012, 10:53 AM
aharder   Well... shit. I bet this was the root of the sup...   May 29 2012, 06:12 PM
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 30th January 2025 - 06:10 PM
