zeezee |
Member ![]() ![]() Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California ![]() |
I've noticed the left rear tire rubbing the fender on occasion.
The right has a little more than 1/2 inch of room. The left has less than 1/4 inch. Is this difference normal? Or an indication of a problem I should be looking into. 195x50 tires. No spacers. The car seems to sit level. Wheels are cambered and toed the same. |
detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
I had simalar spacing between tire and fenderwell, but a rear wheel allighnment cleared that up quite a bit.. could be your rear wheel camber/toe are different for each wheel, also tire wear ect.. get a pro rear wheel allighnment and see the truth.. rubbing is not factory ..
Lo-Fi Version | Time is now: 25th June 2024 - 10:55 PM |
