Weber IDF always rich- Please help! |
tornik550 |
Jun 13 2010, 08:08 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have dual weber 40 idf's. I cannot get the mixture correct no matter of the changes that I have made. I foul the plugs with dry black soot in only minutes. The car runs fairly well. Could be fine tuned however right now I am working on gross tuning. Heres the background info-
Setup- -1.7l case now 2.27l by changing jugs to 96mm and crank to 78.5mm -2.0l heads (I also have stock 1.7l heads, I have had the same issue with both heads) -A "fairly aggressive webcam camshaft setup for carbs". I do not know the exact lift and such. The previous owner increased the displacement from 1.7l to 2.0l. He changed the cam when he rebuilt the engine. When I rebuilt the engine, I used the same cam. I had this rich mixture issue before and after my rebuild. Carb info- -Dual weber 40 idf's freshly rebuilt with new needles and seats -main jets 120 -air correction jets 200 -tubes- f11 -idle jets 50 -vents 32mm -floats set at 10mm (rich mixture), 11mm (rich mixture), 12mm (rich mixture) -fuel pressure at 3.5 Other Info about my engine- -MSD 6al ignition -MSD Blaster 2 Coil -Bosch 050 distributor with pertronix -Autolite 63 spark plugs gapped at .030 I have tried a few things however I have not been able to change the problem. I only have a set of larger mains which obviously didn't help the issue. I have checked to make sure the needle is seating properly. I have removed the air correction jets to see what would happen- no major change in the mixture. I have a set of 34mm vents on the way however I doubt that will change much. It seems to me that with the carb setup that I currently have, I shouldn't be fouling the plugs after running the engine for only a minute. Any ideas would be greatly appreciated. (Yes, I did post something similar on 914Club. I am trying to look for as many ideas as I can find). |
tornik550 |
Jul 1 2010, 07:03 PM
The Solution
Attached image(s) |
Lo-Fi Version | Time is now: 30th January 2025 - 06:01 PM |
